Massive thanks to @ICBM for all your help and advice. Sorry if I was annoying with all my questions but I really am grateful. The taper reamer worked perfectly for enlarging the pot holes.
Not sure. I'll give it a try tomorrow. I guess the orientation of the socket in the cavity doesn't matter, which I'd not thought about.
Really pleased to say it all works perfectly. There's no longer any buzz that there used to be, switches and pots all work well and the Pribora Voodoo pickups sound lovely. Very pleased
Yes I think they need lowering...will do that. Also on the neck pickup the magnet under the B string sits just below the pickup cover. Not sure if it's meant to or not. Sounds ace though!
Following on from this, I need to make some improvements to my Telecaster, which is quite buzzy.
I probably don’t want to go down the route of totally shielding the cavity (not initially anyway), but I definitely want to replace the wires going between the volume pot and the jack socket.
At the risk of sounding a bit dim, what type of shielded cable do I need to get? Could someone point me in the right direction? So I need two lengths of shielded cable that I then twist together for maximum noise reduction?
