WTB Jazzmaster parts Pickguard, Knobs, Electrics, Pickups, Trem, Bridge...
lovestrat74lovestrat74 Frets: 2530
edited April 2020 in Parts £
Want to put a jazzmaster caster together, so looking for all of the above. The PG needs to be of the american pro variety with the switch at the top and no rhythm holes.
Let me know what you have got....
  • lovestrat74lovestrat74 Frets: 2530
    @Funkfingers did you say you had a bridge?
  • dallcorpdallcorp Frets: 139
    edited April 2020
    I've a couple of Jazzmaster Trems.....first one is a no-name relic, perfectly functional though, £35 inc post PPG. Second is an OEM Fender unit with ""Pat #" etc (think it's from a Blacktop Jazzmaster?)£45 inc post PPG.......send me your email and I'll fire you some pics if you are interested?
  • FunkfingersFunkfingers Frets: 14448
    Yes. I have the redundant bridge from my Fender AVRI’65 Jazzmaster. By this, I mean just the bridge and not the tailpiece, the arm or the “thimble” inserts.
    There is a bunch of boring/technical stuff to be said about this bridge. I shall save that for a PM.
    My stock AVRI’65 pickups could also become available if/when I manage to source a neck position SD Antiquity 1. These will have to be offered without covers or screws.
    The output conductors of the AVRI pickups comply with the traditional circuitry and control layout, using the brass screening plates as part of the grounding path. I need to check whether there is enough cable to go between the bridge/Treble position pickup and the Am Pro selector switch location.
    PM'd all ^^
  • RonantianRonantian Frets: 890
    I have a creamery dirty shirt humbucker bridge pickup for JM if you’re interested in something higher output
    How high?
    It’s 13.6k, with an alnico 8 magnet.
    Thanks but probably a bit too high for me
  • ICBMICBM Frets: 72407
    I have a pair of bridge thimbles, if you need them - as well as a complete MIJ Jazzmaster bridge, but Funkfingers beat me to that...
    Sorry bit confused, do you have a bridge? If so what radius?
    Yes, I do - stock MIJ Fender, complete with thimbles. A Jazzmaster bridge has adjustable radius :).
    £15 including postage.
    Top to bottom;
    Fender AVRI Jazzmaster/Jaguar bridge
    Staytrem bridge (fixed 7.25" radius Mustang-type saddles)
    Squier Vintage Modified Mustang bridge. (Saddles are stock but resemble simplified Jaguar/Jazzmaster type.)
    https://i.imgur.com/6jbdvHj.jpg
    https://i.imgur.com/tt2pS9M.jpg?1
    Mine is the same as the top one in Funkfingers' pic but has metric screw threads not imperial.
