That said, I'd do as @SteveRobinson suggests - I'm in the middle of procrastinating getting on with one right now. If you use 6mm MDF to make the original, it's quick and easy to cut and shape; you can then use that to make a working template in thicker MDF that will have perfectly parallel sides, so you can make multiple depth passes.
I've made countless like this & it's not as painful for your pocket if you batter it with the router & have to make another
