Getting a template made
4114Effects4114Effects Frets: 3131
Any ideas where best to get a custom template made for a bass body?
Got the crazy idea to make a Yamaha SBV 500, but templates not readily available anywhere, so need to have one custom made/laser cut out of acrylic or MDF
Anyone on TFB offer that service?
Cheers!
  • CorvusCorvus Frets: 2970
    Can you find a PDF or DXF or similar? If not you may as well roll your own. Scaled up pics and such, grid paper maybe etc or use a vector package. If you farmed it out you'd be paying time to do that anyway, if there's no layouts out there, so may as well cut to the chase. As a bonus you could come up with a modded shape if you felt like it.
  • 4114Effects4114Effects Frets: 3131
    I've already drawn up the plans to scale as a PDF - I just need to send that to someone/somewhere who can laser cut it :)
  • SteveRobinsonSteveRobinson Frets: 7091
    Why not do it the old fashioned way- print it, stick it to MDF, cut round and sand to the line?
  • FatPeteFatPete Frets: 683
    https://www.razorlab.online/ will laser cut in 3mm MDF and ply or 3mm and 5mm acrylic. It might be worth searching for makers groups near you, but they're probably not that likely to have a big enough cutter. Razorlab will want a .ai or .svg file.
    That said, I'd do as @SteveRobinson suggests - I'm in the middle of procrastinating getting on with one right now. If you use 6mm MDF to make the original, it's quick and easy to cut and shape; you can then use that to make a working template in thicker MDF that will have perfectly parallel sides, so you can make multiple depth passes.
    Trading feedback: Trading feedback
  • MLten80MLten80 Frets: 162
    edited April 2020
    +1 on Steve's suggestion
     I've made countless like this & it's not as painful for your pocket if you batter it with the router & have to make another
    Nice one. 6mm MDF ordered, should give me something to do ... Cheers for the suggestions
