Pickguard, making holes bigger
I need one of the holes in a pickguard bigger to accommodate a 3 way toggle switch. Would using a drill bit be a bit brutal? or is there a tool you'd recommend for the job?
  • ICBMICBM Frets: 72556
    Hand taper reamer.
    You could probably use a hand countersink too, mostly they're 1/2" diameter which is the size you need.
  • FunkfingersFunkfingers Frets: 14553
    +1 for reamer.
    The more brittle plastics can chip or shatter when drilled.
  • StevepageStevepage Frets: 3061
    Thanks, I bought a reamer yesterday and it did the trick. Quite a handy little tool
    I always mention this unexpected bonus use, but it's not entirely obvious so I think it's worth it... if you need to tighten a jack socket nut where you can't easily get at the other side to hold it and stop it turning - eg on a 335-type guitar - just lightly jam the reamer into the barrel and it will grip enough to tighten the nut.
