Track 1: VST: Pulse (Lancaster Audio)
Track 1: VST: Le456 (LePou_plugins)
Track 1: VST3: OrilRiver (Denis Tihanov)
________________________________________________
Telecaster American Deluxe, Cornell Romany amp, without the talent to use them properly
To be honest it's never a good idea to upgrade your version of anything to anything until your sure everything will be ok. I've had several calls about Calilana and apps no longer working ... in some cases the only solution was to roll back using time machine
If so then yes this will probably be the plugins are 32 bit and they are no longer supported.
Sorry.
Hopefully you have an imagine you can go back to if you need those plugins, otherwise you will have to manually roll back.
If you were upgrading from a version of Catalina to another version of Catalina then this won't be the issue.
It could be permissions, but that would also be quite weird.
empyreanaudio.co.uk || liberascientia.bandcamp.com
https://support.apple.com/lv-lv/guide/mac-help/mh15216/mac
https://www.macworld.co.uk/how-to/mac-software/downgrade-macos-3581872/
Hope that you manage to do it.
In short--if it works -don't break it (upgrade)
sorry.
The biggest headache will be if you have projects with 32 bit plugins I think, I have 32 bit versions of Reaper 6 running on older PC's, and haven't run into problems YET, but it is early days for me and I have systems set up to basically just play back, without plugins at all.
Maybe check the Reaper forum to see if anybody has more specific advice re- Catalina, but as you have already done the upgrade, you will have to get around it somehow.
I try and leave projects in a state that does not rely on plugins, ie, I render audio files with FX printed, everything is retrievable with audio files.
