Zoom calls etc - mixing in live guitar?
Trying to figure out how to do this in anticipation of attending a music lesson.
Ideally, would want to mix guitar through software via a usb interface with a backing track e.g ireal pro. I think Zoom only allows one audio source but presumably, this is get-around-able...
Anyone done it?
  • bbill335bbill335 Frets: 1385
    yep. you can tell zoom to route audio through an external interface, so you can DI your guitar in just fine. but you will need a mic to use through the interface as well.
    if you need to use a built-in mic on a laptop or tablet, there might be a workaround using the audio share settings (they're confusingly buried in the screen share options).
  • hasslehamhassleham Frets: 607
    Soundflower might help
