Could you use this for neck profiling?
So you have a neck profile you love and want to replicate it on another neck. Would this work?
https://www.sakertool.co.uk/pages/adver?gclid=CjwKCAjwxLH3BRApEiwAqX9ardtidsdLz-RVWiWdEnRdtgQxZeGt2zjwetIWgJEljDLYHS8eLvKoUhoCz3gQAvD_BwE
  • WezVWezV Frets: 16815
    Yes.  You can use it for taking a copy of the contour at specific frets.
    You can then use the facet method of neck carving to duplicate it.
    You can also make thicker templates for checking the carve as you go
    You can get fine metal ones too, but tape the neck before using it
  • RolandRoland Frets: 8792
    You can get smaller ones, with thinner sections, which give a better level of precision. I used one last week to compare neck profiles of several different guitars
  • lovestrat74lovestrat74 Frets: 2545
    :+1:
    Do you know where to get the smaller ones @Roland ;
    Mine probably came from Screwfix
  • guitargeek62guitargeek62 Frets: 4198
    Try the Borrowers
  • JimJim Frets: 20
    I have a metal one approx. 4" wide with small pins. The pins are nice and stiff meaning it holds the profile when you move it around. I took some measuremnts of a neck I was copying at 1st fret, 5th fret, etc etc and then traced them onto an offcut of wood, cutting them out and essentially making a neck profile gauge.
  • mrkbmrkb Frets: 6940
    Crimson guitars sell one with thin metal pins
    Karma......
    Ebay mark7777_1
    I got a cheapo from toolstation the other day. Not refined enough really, but gives you a rough idea. Had I known about crimson I would have gone for that one..
