How do you know when you need to shim the neck?
Is it just a case of not being able to get a low enough choke free action?
New body coming soon and would like to level up my setup skills somewhat.
Thanks in advance.
  • ICBMICBM Frets: 72783
    When you can’t get the action right without the bridge saddles being too low.
    Ideally you want the saddle height screws to be very close to flush with the tops of the saddles, so they don’t stick up and catch your hand.
  • soma1975soma1975 Frets: 6913
    Cool that is a great rule of thumb I'd not heard before.
    Do you have a fave material for doing it or will some playing cards do? NOS ones obviously.
  • guitarfishbayguitarfishbay Frets: 7964
    I’ve used business cards because usually that’s what I’ve had that’s the right thickness
    Any available card or wood veneer depending on the thickness.
    I don’t like the full-size wooden ‘wedge’ tapered shims though - they’re unnecessary and in my experience don’t sound as good as a simple shim at the end. Really...
  • prowlaprowla Frets: 4975
    ...if the neck is straight!
    1st adjust the truss rod, then the action.
    I use cuts of aluminium food trays; you can cut strips and fold them over to suit the required thickness and they compress to a solid piece. (Wash them first!)
    Thanks all
  • TTonyTTony Frets: 27788
    And don't forget that you can increase the angle by doubling up the shims used.
    I had one (self-built!) guitar where I needed to shim the neck to get the strings higher at the bridge.  I cut one old business card to fit the front 2/3rds of the pocket, and then another to fit the front 1/3rd.  That made quite a difference to the string height at the bridge.
  • stickyfiddlestickyfiddle Frets: 27384
    Basically if Strat or Tele type of bridge, it's whenever you're getting the grub screws shredding your right hand.
    For Jazzmaster/Jag, or a Tele with Bigsby - it's always, and don't be afraid of big shims
  • andy_kandy_k Frets: 824
    My experience is that because I switch between LP styles and Strat / Tele styles, I have tended to shim my stuff to get the feel more like a tunomatic bridge, sometimes the grub screws aren't long enough.
    It is to do with the feel of the picking hand on the bridge / body.
    You cant shim a Les Paul.
