Schaller BM 'heads have a similar area back plate to the stock Asian ones. Again, make certain of the key shaft length before ordering.
Hipshot Ultralites will look right from the front but leave original fastening screw holes and an area of pallid finish exposed around the back of the headstock.
IMO, if you are going to plough this much investment into your bass, you might as well choose three Ultralites and one Xtender for the E string.
was kinda hoping one of the other manufacturers made a drop in replacement for a bit less cash.
Ultralites all the way.
The no-name ones on the MIM PJ had started to fail with the black plastic sheet cracking so they needed replacing.
The Hipshots are finer ratio and better quality.
Worth it? Maybe, as they were a drop in, no drilling.
