Tele wiring mod suggestions?
I have a Squier Classic Vibe 50s Tele. I am happy with the pickups and I’m not planning on a change.
It has the standard three way wiring.
I am open to ideas on wiring modifications, the kind of thing that gets a bit more variety out of what’s already there, rather than requiring different/ additional pickups etc.
The kind of things I have in mind are the four way Tele wiring system (with the additional sound with the bridge and neck pickups together).
I also remember seeing a video once of Jerry Donahue explaining a five way switching system in his Teles. Has anyone done that one and does it give decent results?
Are those two worth pursuing and are there any other suggestions?
Thanks.
  • MusicwolfMusicwolf Frets: 3677
    I have a Baja with the 4 way switch (which puts both pickups in series) plus the phase reverse switch on the vol pot.  It's not my most played guitar but, when I do use it, I tend to stick to the old three way options.
  • ICBMICBM Frets: 72644
    There are three main options -
    Series - the standard use for a 4-way switch - seems popular but I find the sound a bit muddy and uninspiring.
    Out of phase - funky and thinner-sounding.
    Some sort of preset tone - either like the original 50s Tele (neck pickup with a very bassy tone) or the ‘Eldred mod’ (a smaller cap which gives a honky fixed-wah type sound).
    You can do all these with a 4-way switch. The Jerry Donahue ‘half out of phase’ sound can also be done with one. The full JD wiring has both that and a preset tone, but you can only do that with a 5-way ‘superswitch’, which often won’t fit in a standard Tele control cavity - a normal Strat-type 5-way won’t work.
    Either series or out of phase require the coil to be separated from the ground on one pickup - most standard schemes do it on the neck pickup, but in fact it can be easier to do it on the bridge, especially if there’s already a separate ground wire to the bridgeplate.
  • Winny_PoohWinny_Pooh Frets: 7802
    I like the series mode on a 4 way. Get a 4 way and install a kinman style treble bleed mod (two components) on the volume pot.
  • TTonyTTony Frets: 27690
    Or a blower switch - you could do that with a push/pull (or push/push) on one of the pots.
  • RedlesterRedlester Frets: 1072
    Thank you everyone. That’s very helpful.
    @musicwolf The Baja mod sounds intriguing. I will check out a demo of that guitar to see what those basic sounds are like. As for actually using them you raise a good point. I did a fairly elaborate rewrite to my Strat some years back, but I still usually revert to the classic wiring.
    Thanks @ICBM. That’s a good practical tip about the JD wiring.
    Lots of food for thought here. There is a very good guitar workshop near me and they’re friendly people, so this has given me a good basis for further discussion with them.
    Ta.
  • RolandRoland Frets: 8756
    I use both of these. Series is useful when you want a warm, fat sound for a solo.
  • FunkfingersFunkfingers Frets: 14573
    The so-called half-out-of-phase sound is more Stratocaster-like. It requires a capacitor on the selector switch. (The Donahue circuit employs this.)
    The series, in phase sound seems more usable when the neck position pickup is a “Twisted”, Stratocaster-voiced type. Almost P90-ish.
    My suggestion is for the Freeway 3B3 six-way selector switch. This offers the same six pickup permutations as the Fender four-way + S-1 system but is more logical to use and less likely to physically break.
    The majority of these wiring changes will require a modification to the neck position pickup.
    Unless you are very lucky, the metal cover will be grounded via the black/start output conductor.
    Disconnect one end of the short jumper wire between the soldering eyelet and the cover. Solder an insulated wire to the cover, long enough to reach a grounding point in the control cavity.
