Laptop spec help
Hi all
I have been looking at older second hand laptops to get me started on recording my own music. There's two that have been offered by a forum member, but  neither of us are well up enough to know how the specs below relate to how well they would run a DAW programme.
My plan is to initially use one of the free programmes until I get to know what I am doing.
Below are the specs - would either be able to run something like Cakewalk for instance? Sorry that I can't get the columns to line up properly, but it should be reasonably easy to see which is which.
        HP Pavilion G72 laptop                                         HP G5 250 laptop
Screen17" 1600 x 90015" 1366/768
HD223 Gb (250) Not SSD464 Gb (500) Not SSD
RAM8 Gb4 GB
Processori3 - M350 2.27 GHzi3-4005U 1.7 GHz
OSWin 7 ProWin 10 Pro
Power SupplyYesYes
32 or 64 Bit6464
HDMIYesYes
DVD DriveDVD RWDVD RW
USB ports33
BluetoothYesYes
  • Danny1969Danny1969 Frets: 10418
    Spec wise both are fine. These models don't have the best plastics for constant travel use but for home use where they aren't  constantly opened and closed they will be allright.
    Win 7 Pro can cause problems with some interface drivers ... as it needs drivers to be signed and certified before it will allow them to be installed. You can navigate around that on startup but it can be a pain. Likewise Win 10 pro . For audio use your better off with home versions.
    Both models can be reloaded with home versions so that's not a deal breaker
  • MartinBushMartinBush Frets: 254
    Cheers Danny 1969
    How easy is it to load the home versions on a second hand computer?
    By interface drivers I am presuming you mean USB audio interfaces. My plan was to get one from ebay and my selection would be based largely on price - does that seem OK or are there ones to avoid?
    On HP laptops it's escape and then F10 to enter the BIOS setup. Then you can change boot order to USB and load Win 7 home or Win 10 home from a bootable USB stick ... using the MS Media Creation tool which is a free and easy to use tool from Microsoft.  So very easy to do. Drivers not included in the OS are free to download from HP support.
    My tip for cheap USB interfaces is Mbox  .... because people think you need Protools LE to run them but they run fine under Reaper and other DAW's but also allow you to use Protools LE8 which is a great home DAW
    Cheers.
    With a lot of this at the moment I am very much in the mindset of "if I plug this in here will the sound come out there and go into there?" - I'm not a technophobe, but I am used to using things that have been set up and all I have to do is operate them :)
    This will be a learning experience for me on the tech as well as musical side.
