And the handling fee.
So whatever the price is, make sure you allow for another 25% or so when deciding whether it's worth the hassle.
Be aware that some makes don't like to make it easy to get spare parts from the grey import market.
Delivery costs will be mental and personally, I would expect it to be broken upon arrival.
Also, if gets damaged in transit, it's a pain in the neck.
I contemplated getting the transformer swapped over but in the end decided to just explain to the seller what the issue was and return it. He happily obliged and sent a refund, and proceeded to relist the item with the caveat "has a USA lead so needs an adaptor".
I can only think that seller tried the same as you were planning and imported a US spec amp as it was cheaper and didn't realise about the voltage difference; then decided to shift it on eBay rather than send it back to the US.
