New toy at work - laser cutter!
4114Effects4114Effects Frets: 3131
in Making & Modding tFB Trader
So now I can very easily make amp front panels ...
... also cuts up to 15mm plywood and 12mm actrylic so I can make guitar routing templates, logos, cabinet faceplates, the possibilities are (almost) endless.
Anyone on here need any laser cutting, drop me a message I'll see what I can do :)
  • mrkbmrkb Frets: 6879
    Ooh interesting. I assume it can cut or engrave/surface burn depending on the settings? You could do great scratchplate graphics.
    Karma......
    Ebay mark7777_1
  • WezVWezV Frets: 16725
    Awesome stuff.   I may need some plastic logo discs soon as I just used my last ones from an order I did over 10 years ago
  • skippy76skippy76 Frets: 616
    Awesome Kit, very jealous!
  • DanielsguitarsDanielsguitars Frets: 3297
    Very nice, I'll make a note for future reference
    www.danielsguitars.co.uk
    (formerly customkits)
  • KalimnaKalimna Frets: 1540
    Fabulous stuff :)
    If you were to take files for cutting, what format do they need to be in, out of interest?
    Cheers,
    Adam
  • 4114Effects4114Effects Frets: 3131
    Kalimna said:
    Fabulous stuff :)
    Cheers,
    Adam
    DXF, AI or PDF would be fine :-)
  • vizviz Frets: 10699
    Or bitmaps presumably
  • m_cm_c Frets: 1243
    Was I the only one who was hoping to see pics of the laser cutter in this thread? :-/
    Good point. I'll take some :-)
  • UncleBiffUncleBiff Frets: 52
    Can it cut our MOP and wood logos?
    edited July 2020
    not sure if the tech has moved on, but it used to be that laser cutting only work on really thin pearl.  On something of inlay thickness  the light gets refracted inside before it gets through the material...it quickly turns to dust.
    Even Abalam (laminated abalone sheet)was too thick at 1.3mm... I  wasted a sheet of it finding out about this issue
    I did have some really thin abalone veneer (0.3 mm) ones cut once.   They were just glued under lacquer  rather than attempting to inlay.
    Kalimna said:
    Fabulous stuff :)
    Cheers,
    Adam
  • NPPNPP Frets: 236
    so no pickguards?
    so no pickguards?
    Not from solid shell.   Thankfully most are plastic ;)
  • JonathangusJonathangus Frets: 4543
    (Thread resurrection)  @4114Effects - you have PM.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
