The pickups are Oil City Brass Knuckles. Since these were special order only I decided to go with clear bobbins so that the coils are visible. The pickups have individual magnets in both coils, rather than bar magnets and slugs. I’m still deciding between partial taps or parallel coils for more Strat like sounds in the in-between switch positions. There’s space in the switch cavity for two trim pots.
What I’m finding so far: the guitar neck is in exactly the same position whether I’m sitting or I’m standing with it on a strap. It encourages good hand position and technique. All that body shaping helps too.
I made the wrong decision about neck dots. They are black, and don’t show up easily in poor light. White would have been better, and larger, centred on the fret board/neck join line edge. I’m not sure I can change the size or position, but I might drill them out and fit white dots.
Aside from the pickup adjustments there a little more work to do. I left the end of the neck unfinished because I wasn’t sure which head piece to use. I need to cut off the spare wood and tidy that up. I can’t find the pair of black strap lock buttons which I was going to use. I’ve fitted chrome for now, but I need to get some more black buttons next time I place a parts order.
Gratuitous pic:
It’s needed several days to get rid of an annoying tone on the top string. It sounds like the string rattling against the frets. The frets are perfectly level where they need to be, and there’s fall off above the 15th. Raising the action wasn’t curing it. I’ve even wondered about wolf notes. The culprit turned out to be the J Custom bridge. Each saddle block has a little silver insert which carries the string. The top E insert had a small groove at the string contact point which the string vibrated in and out of. The insert also rocked in the block. A few careful stokes with a needle file, and a lot of blowing clean, seems to have sorted it.
The pickups have been up and down a number of times whilst hunting for non-existent wolf notes, and finding the best compromise of heights. I’m glad that they’re screwed into threaded inserts. I’ve also reversed the wiring on the neck pickup because they were out of phase when both pickups were in parallel.
Before deciding whether a guitar is finished I like to play it in a band context. This one has got trim pots which control how the pickups are tapped, and I won’t know whether I’ve got those right until after Sunday’s rehearsal.
Rehearsal feedback:
Well done, a great build, very nice, its looks superb.
I have installed the same headpiece on my Strandberg type design, I have a nut before the zero fret, so I have no problem with string spacing. Cutting a decent nut on a fan fret was problematic, I'm on my third attempt. still not happy.
