my interface (Mbox Pro 3) and its really very quiet, much less noise than in the days of me putting a 57 in front of a real amp. Not sure what’s going on there, earth loop maybe?
I have the same issue with an Effectrode valve buffer and my HX Stomp but it goes away once I plug the USB cable directly into the laptop rather than via a USB hub. That's because the HX Stomp doesn't have a grounded PSU and there's some sort of mild ground loop style noise with that pedal. Once it's grounded via USB, the noise levels are really good, it's clearly not the pedal itself that has the issue.
