What is the correct way to set up a Strat bridge?
RaymondLinRaymondLin Frets: 11879
Is it picture 1 or 2?  It seems I seen some photos of the heel of it up and some are down.  Mine are currently down.  Is it a preference or there is a correct way?  Fender spec is 3.2mm which seems kinda high.  I think if I do that it will raise the action far too much and I will need a shim in the neck pocket.
  • John_AJohn_A Frets: 3775
    All depends if you want upwards movement
    Pros - Ability to do nice trem shimmers, tuning stability
    Cons, double bends don't work as well, snap a string and you go out of tune
  • ICBMICBM Frets: 72445
    For me 3.2mm is a bit high - I like to be able to pull up about a semitone on the top string, which usually needs it a bit flatter than that. But I do prefer them floating - I think they sound better like that.
    The most important thing is not to overtighten the front pivot screws - you must be able to pull the bridge back to fully flat without the plate binding against the underside of the screw heads. It's easier to assess this without the strings on - and contrary to popular wisdom, there is no benefit to raising the middle four screws as long as they're all set correctly.
  • if I do that it will raise the action far too much and I will need a shim in the neck pocket.
    The action should be set with the saddle screws and not the tilt of the bridge.
  • tone1tone1 Frets: 5171
    edited August 2020
    Inner screws raised slightly with 2 outer screws just touching... the photos look opposite to that
    https://support.fender.com/hc/en-us/articles/212774786-How-do-I-set-up-my-Stratocaster-guitar-properly-
  • RaymondLinRaymondLin Frets: 11879
    It is but the Low E is as low as it could go at the moment and it is at 1.75mm at the 12th fret.
    I haven't posted photo of my guitar, those are just photos showing the back of the bridge and one is touching and one is not. The question is which one is right/prefered really.
    I like it just floating in Standard tuning but decks out flush to body in E-Flat
  • guitars4youguitars4you Frets: 14304
    flat or floating is a matter of taste
    Some have it flat, with 5 springs and the trem will not  move - But they feel it adds more 'resonance'
    Others still have it flat, but only a touch is required on the arm for down pitch
    Others have a touch of up so only slightly raised
    Others have more up pitch - J Beck amongst this preference
    ref 3.2mm from Fender - I see nearly all C Shop models arrive like this and I adjust accordingly - I can't recall the last time any one required this option
  • stonevibestonevibe Frets: 7155
    Usually, I would balance it determined on how much of an up bend/pitch up I want, as in a semi-tone for example. Or just deck it and get a little more sustain.
  • Float, deck or block...floating let’s you shimmer with the bridge since got upward and downward movement but you have to bend further to reach pitch and a string break ends your night. Downtuning likely requires complete set up.
    deck let’s you use the bridge purely downward, fixes some of the issues above.
    block nothing is moving, it’s a hardtail basically. Gives you the most sustain.
    All personal preference. I’ve literally just popped my strat to tech today and have it floating. If I was gigging it I’d have it decked. If I owned multiple strats I’d probably have a variety.
  • Fun thing to do with floating by the way (ie picture 1) play the low e and let it ring, bend another string eg the G string at 15th fret bent up a whole step without plucking that string.
    That sounds too low, assuming the rest of it is adjusted correctly. I usually end up with it around 2-2.5mm, although I don't normally measure it. 1.5-1.75mm on the top E would be about right.
    You should be able to get it to about that with the bridge floating slightly and the saddle screws flush with the saddle tops for the Es, D and G, and just slightly above for the A and B. If not, a small shim fixes it.
  • FunkfingersFunkfingers Frets: 14475
    Floating, like OP photograph 1. Gap set to 3/32”.
    Yes. Raising the bridge baseplate will raise the saddles marginally. Adjust them downwards to compensate.
  • NeilNeil Frets: 3627
    I have one floating and one screwed down.
    If you hardly use the trem (like me) deck it.
  • stickyfiddlestickyfiddle Frets: 27119
    I deck mine. I do enjoy a floating strat trem but I like double stops and those go to hell when you have the trem set floating.
    I obviously need a second strat...
    I can slide a piece of paper under it now...I kinda like it where it is so will leave it.
  • poopotpoopot Frets: 9099
    edited August 2020
    The correct way of course is:
    1) remove trem arm
    2) throw trem arm in bin
    3) add five springs as below
    4) deck the bridge flat to the body as below
    5) enjoy the tonez - men will envy you - women will fall at your feet - you will become a guitar hero... ( works that way for me anyway )
  • axisusaxisus Frets: 28339
    Floating for the win
  • p90foolp90fool Frets: 31619
    I set them so that pulling the arm up all the way gives you a semitone up-bend on the B string and a whole tone on the G.
    Great for country licks.
