Ok, I'm thinking about recording at home. I currently have an iPad Pro, a Macbook Pro from about 2014, and very little other relevant kit.
Where do I start? Let's assume I wanted to record with guitar, bass, drums and vocals for now. So that means as a minimum some sort of interface, and some sort of mic, and the relevant cables to connect everything. I'll want to put drums in via Roland TD17, so that means an interface that can do both stereo input and MIDI.
Software-wise, Garageband seems a good bet - I've used that before for simple single-guitar-track stuff without any processing, either with Helix native or the in-built amp/fx stuff. Is there another option that might be better in the long run, or am I going to run into issues of needing a million plugins that will cost a fortune and won't run well on this laptop?
Helix Native is an obvious starting point for guitar & bass sounds, though I'm wondering about an HX Stomp as well for general use. Either way I don't think I need to worry much there
I'm well aware microphones are a very expensive rabbit hole, so want to keep that simple. I'm in an apartment, so not going to be recording loud guitars any time soon, so it's really just something for vocals and acoustic guitars right now. I'm well used to SM57 & 58 from gigging, and I fell in love with the Beyerdynamic M88TG when I sang into one a few years ago, so that seems a good starting point, but will I want a condenser as well?
Help?!
I guess I'm wondering if I might want to mix 2 mics and the pickup on the acoustic plus vocals, though in that situation I wonder if 2 mics might actually be plenty to capture both. Google tells me my drum module (TD17) can do midi via USB so maybe MIDI isn't strictly needed but again it would be nice to have the option for future.
On software, Garageband was the initial thought simply because it's free and I already have it on both devices and I know it's quite powerful once you learn it. It probably makes sense to start there and only move on if/when I start hitting limitations with it, which may take some time.
Plenty of tutorials on Youtube for whatever you pick, but my suggestion is Garbage Band (yes I'm kind!) is a bit too basic, even for most n00byist of n00bs.
Studio One Free would be a better option IMHO.
I like the look of the Focusrite 4i4 as it seems to do everything I need. Has anyone used their stuff?
Mac is generally OK.
Studio One is probably better for you than Reaper.
Or Logic.
Audio Interface:
Presonus Audiobox iTwo - works with all these devices without needing an Apple USB/Camera kit. Two combi inputs plus 5-pin MIDI in/out/through. 5-pin MIDI can be quite useful, as iPads only have one input socket. Having everything coming through the one wire from your audio interface into your computer/device is helpful. Also, some older MIDI keyboards/drumkits won't have USB connections and only have 5-pin MIDI - if you ever want to use one of them.
Mics:
The mics on my iPad and iPhone (esp. the iPhone XR I have) were more than good enough to get started and get ideas down, play around with the software, etc. I bought the iTwo and used the SM58 I owned at first. Then I bought an SE/X1 condenser for vocals/acoustic. Then I bought a pair of Rode M5s for live stereo recording. Then I bought a Shure MV88 so I could record band practice on my phone without needing to take any other gear. The internal mics are too sensitive and high volume recordings brick walled and clipped. Thats where I've stopped.
Apart from the MV88, I could do without any of the mics if I had to. I'm not making an album when I record - just getting ideas and demos down, and capturing the moment.
DAW:
I do most of my recording on the iPad using Garageband. It's really very, very good for the needs of a musician who wants to record themselves and be their own engineer without the recording process taking over the performance (IMHO).
I've got Logic on the Mac, but don't use it much for recording myself any more. I do use it for recording other people when I'm not the performer. It's far too big and capable for me to learn it properly and I used to spend a lot of time learning Logic when I could have been doing other things, so I stopped.
I also use GB on the iPhone, but there's another app I use called "Multitrack DAW" which I also use on the phone for audio recordings "in the field". I find it easier to get good stereo recordings at band practice, in my mates kitchen, etc. But it's only for audio recording, not MIDI tracks.
Guitar AMPS:
The software amps in GarageBand are good enough for ideas. I've got a Headrush Gigboard and use that for guitars and basses sometimes, just recording the audio output. I don't like it as an audio interface, although it can do that. I recently trialled Helix Native, but that forces me to use the Mac and Logic. It wasn't a step up in sound quality for me, just many more options, so I didn't buy - even though I'd have gotten it cheaply as I've got an HX FX.
I also own a silent load box (armAudio L850, £50) and a BluGuitar Blubox IR cabinet emulator. That's what I use for electric guitars these days - my own amp, no speaker and straight into the iTwo. Easy and sounds good.
But, TBH, all you need to get started is a pair of headphones, Garageband on the iPad, plus (optionally) an inexpensive audio interface with MIDI sockets and whatever dynamic mic you use with your band.
You need to start to play the game to understand what you really need personally. enjoy the rabbit hole! :-)
So recently I was talking to a band member who wanted a music computer capable of recording his songs and sharing ideas with me. So he asked what I used and then he went on Ebay and brought it.
2008 iMac £100
Mbox Pro firewire audio interface £40
Protools LE download from Digidesign free
No drivers to install, bugger all latency to worry about, superb Xpand softsynth, brilliant piano and organs, great sampler, Digidesign 11 amp sim and Sansamp sim for bass.
So £140 spent in total. Which is actually £20 more than I spent on the the same setup There is a audio track limitation of 32 tracks but you can bounce down if you need more. You can have as many instrument \ midi tracks as you like. You can't install the latest plugins and you can't run the latest soft synths. Personally for me these aren't issues. The built in EQ, compressor, reverb, delays etc are better than the included ones in a lot of DAW's and the included VI's are very good indeed .. to the point my live keyboard rig is a 2006 Macpro running PT LE with an Mbox Pro.
So basically we have these machines which just do one thing - run Protools LE. Nothing else. We don't care the old iMacs can't run the latest browser, they aren't connected to the internet. They are just for making music and they do it so well.
So that's one way to get started making music on a very, very small budget.
Feedback
I didn't buy an iPad to record. I've had one since they came out. My laptop, though, was a Win 7 machine. I only bought a MacBook to replace it because of Logic and Garageband - even though I'd never used either of them. I wouldn't do it again - although I really like my MacBook now I've got it. But Catalina is the last OS it will ever support and I'm not going to buy a new one until/unless this one dies. I'm more likely then to buy a 12.9in iPad Pro, TBH.
I think a lot of people have had journeys like me. Not coming from a professional recording background, and not realising how little gear you actually need, or how low cost it can be, until you've spent your money and realised it wasn't really necessary.
The problem is that we want to buy the shiny toys because we must need them, right? Otherwise we'll be held back. In truth, we aren't and we don't.
Apple Garageband v.10 is pretty much Logic Lite. Hence, it is a manageable entry point for relative newcomers. If/when you upgrade to Logic Pro, your GB Projects will convert load. There is even a way for GB to upload Logic audio content* to permit overdubbing and file swapping.
I'll start with Garageband, most likely with a simple stereo drum feed just to get the hang of the basics, then move to MIDI and Logic when I hit any limitations in GB.
