Which 'stang?!
13»
  • What's the view on the Squier versions of Jags? They're dirt cheap and as I already have a Strat, but I don't have a Jag or 'stang, I'm slowly getting bad gas for one...
    If you must have sex with a frog, wear a condom. If you want the frog to have fun, rib it.
  • guitargeek62guitargeek62 Frets: 4156
    Not too bad at all, once you've change the bridge!
  • Why? What's wrong with the bridge and what would I replace it with? (Asked out of genuine ignorance, btw, not some snarky defensiveness.)
  • GavRichListGavRichList Frets: 7189
    The saddles are pap. This isn't exclusive to the Squier though, it's a jag thing in general. Pop a staytrem bridge in. Problem solved.
    Yep, it's the only part on my Squier VM that drives me a bit nuts! I've been in two minds about going for a staytrem, or a hardtail and build a duosonic instead with the rest of the bits! The rest of the stock hardware and parts are more than good enough though. :)
