After that you're going to need to look at whether the trem is returning to its "zero" position properly, and if not, why not.
The tuning problems will be caused by the tune-o-matic and the severe string angles at the nut on the middle two strings - more or less inevitable with both these things. Making the bridge rock or replacing it with a roller will help, and cutting the nut grooves with a flare on the headstock side and lubricating them will help, but you may not be able to completely eliminate them.
Do you mean something along the lines of this: https://www.thomann.de/gb/abm_roller_bridge_2400n_ro_n.htm?ref=intl&shp=eyJjb3VudHJ5IjoiZ2IiLCJjdXJyZW5jeSI6IjQiLCJsYW5ndWFnZSI6ImVuIn0=
