Hey guitar hive brain,
Got this in a charity shop for £75 a while back now. I was really skint at the time so was a big purchase but it’s probably my most cherished possession. Always thought it sounded great and has a great big neck and sound. I just connected with it. Plays well and doesn't buzz or fret out. A bloke tried to buy it off the charity shop for more money while I ran to the cash machine but the lady in their said ' it was meant for you'. I took it as a mystical sign.
I have done a bit of research and can see it was distributed by Boosey & Hawkes for Zenith. Inside it says A17 crossed out and and A19 written in. I can see the Zenith decal has been removed on the headstock. 50's, 60's, 70's ?? It smells old and has some nice patina. There is a bottom loaded soft brown case as well. I assume not original but certainly old and a bit musty.
Any info would be very interesting and as always very appreciated.
Cheers,
Steve
https://i.imgur.com/Qn0nZE7.jpg?1https://i.imgur.com/9Xbw3Q7.jpg?1https://i.imgur.com/rnBOLHz.jpg?1https://i.imgur.com/8Fct6Rg.jpghttps://i.imgur.com/ixqnJox.jpg
Feedback
Yes very straight and very playable. Tuning pegs work well. Wow ya great. Honestly the little bit of wear on the back was all from me oh dear. @Jalapeno
About 3- 4 years ago I put D'Addario Phosphor Bronze 013. -.056 on the guitar and have changed a couple of times. Too much for this old lad??
Feedback
Your guitar looks like very fine quality.
Feedback
I think its likely Framus made, but at a lower price point than the equivalent framus model. Left unbound, simpler cosmetics etc. Is the string anchor on the tailpiece solid, or bent metal?
Mine looked like this when i got it
But bridge was half filed through to correct for a neck that needed resetting. I ended up taking the neck off, replacing the board, fitting some extra neck reinforcement and adding a pickup. I also made a plate but still haven't fitted it over 12 years later
Instagram
https://www.framus-vintage.de/en/modules/modells/instruments1b16.html ;
and a 5/52 Atlantis here from 1960
https://www.framus-vintage.de/en/modules/modells/instruments60ad.html
Other than the f-holes, yours sits directly between these two models from the same series
Instagram
Would love to hear what mine sounds like with a pickup. I might have t look into it. Was it difficult to do? I would go to a tech. Definitely time for me to get a decent hard case for it.
Feedback
I have a aged pearloid guard ready to go on mine...one day
I added an end pin jack socket which is pretty easy to do. Then just fed wires out the f hole to the pickup. The plan was to put some scratchplate mounted controls on it.
Instagram
https://i.imgur.com/XnznkRJ.jpg
https://i.imgur.com/ItssukH.jpg
@Jalapeno I will have a look at that Rhythm Chief. My mind is whirring now from the possibilities.
@Johnnyseven interesting. Thanks for sharing. Sounds like there must be a lot of different versions and brandings floating around.
Any one have any tips for a correct fitting hard case?
Instagram
Ooo saw this. Mine isn't this version but looks very similar. Doesn't sound this good either, ha.
