Any midi device capable of sending cc messages should work.
i am awaiting delivery of an Alderandash pedal board....the wooden one with a LID and space underneath....i thought it would be cool to have the (as yet un bought) Stomp hid away inside...and switch from small pedal
If you have a patch/snapshot with NOTHING turned on, then that’s the same as “bypass”, no?
Your next snapshot then has blocks/effects activated, therefore not bypassed?
You can also connect a momentary footswitch and assign this to "all bypass " thus avoiding midi altogether. The Mosky Dual Switch at about £14 would work and is about your cheapest option
The options that the MC6 brings are that when you have the Stomp set up one way (snapshot mode, or stomp mode) you’re then limited to what those options allow - the MC6 allows you to “bypass” these restrictions.
For instance, I use snapshot mode on the Stomp. This means I can’t load the tuner from one of the 3 Stomp buttons. I can load that from the MC6. Also, I have my 3 snapshots set up and and can’t really alter these on the fly, but with the MC6 I can have each of the 6 blocks assigned to the switches on the MC6. So if I’m not feeling the reverb, I can turn it off. If the snapshot doesn’t have my overdrive block turned on, I can activate that on its own from the MC6
What's the point of ownership if no-one knows about it?
