The way I see it is there are 4 options to recording a guitar track on a DAW:
1. Mic amp, through an audio interface to DAW
1.1. Isobox
1.2. Cupboard under the stairs
2. Guitar direct to audio interface to Amp-sim/plug-in to DAW
2.1. Guitar to Amp sim pedal to Cab sim pedal to Audio Interface to DAW
2.2. Guitar to Digital Profiler (Kemper, Ampli, HX) to DAW
3. Amp into OX Box (or similar) to audio interface to DAW
4. Amp LINE OUT to A/D audio interface to DAW
Recording at home requires space, time, convenience and low volume. Here's how I could face these options:
1. I could record in my cellar. However, my old Shure SM58, laptop and my old Audio interface failed to produce good results, with awful latency and nothing like what I actually hear in the room. Time and convenience (family and late night) makes it unsuitable.
2. Play directly into my super spec 2019 iMac with headphones. Frankly, I've never done it. It goes against the sonic joy of playing through incredible boutique and special vintage amps. I'm sure technology has progressed since digital Zoom pedals. Still, it would be silent and convenient. Probably a super fast audio interface would help. I'm thinking an apollo X duo Quad.
3. With all my effort into sourcing amps, the OX box would digitally convert them into some excellent speaker simulations and mics. A good 1200 quid investment plus an audio interface. I could play silently with headphones too. It would mean that the cabs I have at home, which are integral to the sound, would be forfeit. Still, I doubt I will ever own the skills to properly mic an amp. Ox box convenience wins over cabinet sonic glory.
4. I could use the line out on my Redplate into an Apollo X into a DAW. And here I need tFB's advice: would the Apollo handle all the speaker sim and recordings mics internally so that I could practice on headphones. Is there any way to make it a stand alone device (or use an iPad to control it)?
A quality audio interface is essential on all 4 solutions. Is the apollo X duo quad core overkill? I could start with option 4 and see how it sounds.
Will the apollo X plus LUNA DAW with standard plug-ins do me fine (Marshall Plexi is good for me)?
What elements of option 3 (the OX Box) for recording are available through option 4 (amp LINE OUT)?
Please let me know your thoughts and experience of home recording where volume and convenience are paramount.
Now I have an amp cupboard under the stairs, I have a Marshall, a Fender HRD, a Blackstar and a Bugera in there with a mic stand and already rigged mic which I can just put on any of the amps.
Personally I like the Kemper and AxeFX for really heavy sounds but prefer mic'ing an amp for most styles of rock, pop, country
This has been by method of late, as I've never liked amp sim VSTs in Reaper. I recently tried again (for bass only) as I was able to get AmpliTube 4 for free by registering my Focusrite, but I scrapped that in favour to using Bass Professor Mark II (a JS plugin, but I can't remember how I got hold of it). However, I may revert back to the Captor for bass too.
Just because you're paranoid, don't mean they're not after youAs i understood it a 58 has a presence peak ...
Part of my worry is falling down the mic rabbit hole. I’ve enough of them as is.
Is this option 3? A cheaper / better solution to the ox box / Apollo x?
Load box into interface and IRs will do the job nicely. An Apollo would be pointless, because all you're using it for is a line in, not the preamp.
Get a Captor and something like a Komplete Audio 6, plug your amp into the Captor, plug it into the interface and load some IRs in your DAW, probably about £400 all-in. Experiment with IRs to find out what you like and what you don't like. Then, armed with that knowledge...if you feel you need to take it a bit further, get/borrow some of those mics and make your own IRs from your cab and those mics.
I can always record dry signal as well for re-amp later on ...
https://twitter.com/spark240
Reddit r/newmusicreview
reamp a few times with multiple mic placements, levels of gain, fx etc etc and then import the reamps back into logic? On your iMac for that massive guitar sound!...
So the Apollo's benefit of decent preamps and processing power would be pointless?
is this akin to a more analogue attempt at using a looper as a 2nd pair of hands while I move the mic around the room with headphones on to get a decent recorded sound?
While recording is the end goal, silent practice is equally important.
This sounds much better than any amp & mic combination I've tried before.
I tried software amps, like the ones that come with Logic and Digital Performer, as well as Guitar Rig, found them all completely useless for guitar, only useful as special FX for synths or other instruments.
ampli firebox > DAW for me. It sounds great and is so simple to set up. Better than VSTs because there is no latency
Depending on the cab sim built into your amp. I've tried this with some cheaper practice amps and they were not great.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Works for me.
