don’t know about action, sorry
1 - when the action is slightly too low, the initial string attack transients will hit the frets. This actually happens quite a bit before it's really audible as "fret buzz", because it only clips off the top of the very first (and much larger than the rest) string movement. But by doing that, it robs the string vibration of a lot of energy which makes the volume and tone a lot worse. Once the action is just above this point, there isn't as much further change (and on an electric, none I think).
2 - on an acoustic, a higher action at the saddle produces more of a force on the bridge and the top, by simple leverage - that gives more vibration transfer to the top, more volume and a stronger tone. There is a limit though - you don't want it *too* high, or the force on the saddle tends to be more 'forwards' and not 'up and down', so you don't want the break angle over the top of the saddle greater than 45º (when the two directions of force are equal), but closer to that than flat is better. Obviously whether the saddle can be as high - or as low - as this depends on the height of the bridge itself and the neck angle.
So on an acoustic, the 'sweet spot' is somewhere between 1 and 2. On an electric, it's much closer to (or more or less exactly at) 1.
On an acoustic, 2.75mm on the low E is actually not that high an action - I would call that medium really - but check the relief (fret the G string at the first fret and the 15th while holding the guitar normally, and check that there is a small gap of about half the string diameter between it and the 7th fret), and see whether the bridge looks about the right height going by point 2.
I'd already checked the relief, which seems fine. The nut could probably do with a small adjustment but the issue is present when fretted in any case.
The action is actually 3mm on rechecking. The guitar I'm comparing it to has an action of just 1.75mm. That seems ridiculously low but I don't have any obvious issues with that one.
I was wondering about break angles. How do these look? I'm guessing the lower one which I prefer the sound of looks terrible.
I don't think that's what's happened in the second pic though. The owner before me has just lowered the action to a seemingly extreme degree. Sounds great though.
As a couple of threads here show different strings can suit different guitars
What gauge and brand/type of strings are you using, and how old are they?
I can't remember what strings I've got on there tbh. They'll be 12 to 54s. Probably knocking on a bit. I somehow don't think string age is an issue though. I'm lazy with string changing and haven't noticed this before.
Anyway will change these and see what happens.
the wound ones go dead pretty quickly
I use 11s, and find that dropping to DADGAD loses the tone, so I tune up a semitone from that
12s should be OK for tension
If the neck relief was not adequate, that would improve with tightening the strings or using a higher gauge, 3mm should be enough anyway if the relief is OK
Like ICBM says, check the relief
I do it by fretting the first fret with the left hand, and the fret where the body starts (13th/14th) with my right little finger, then tap the string around the 8th to 10th fret. Does it give a proper tap noise, or was it already on the frets?
Very important - check it when holding the guitar normally, not lying down on its back on a bench. The weight of the neck and headstock is enough to affect the relief like that, although more so on electrics with a relatively thinner neck.
You could ask Avalon to shave something off the top of the bridge to compensate for the low saddle. They did that for me this summer on my Avalon A200. They charged £70 for the shave and £56 for couriers both ways.
Email steve@avalonguitars.com, he sorted mine out. It sounds a lot brighter now.
As it happens, I also have an L2-20, which I think sounds fine, but the action and saddle height are, too, so that probably doesn't help much, sorry.
