The one wire Magsafe system uses a micro controller chip to monitor and control the voltage and current draw. It's a sophisticated system of communication between the SMC on the board, the battery and the charger and if the circuit is damaged by a shit knock off charger then your be needing a new board as well as a proper charger.
If you have a good genuine end (the magsafe end) then you can modify another charger as the micro controller side of things is actually in the magsafe connector it's self.
