So I’ve picked up a nice Headrush Gigboard from
@mboz and I’m looking at my options for sound output.
I tried it into my hifi yesterday as id rather integrate it into a living room setup than get an frfr. It sounded louder & ‘fuller’ from the headphone out into the 3.5mm aux in than it did the r+l stereo outs into the stereo aux ins on the hifi.
I thought the cab modelling would be present in both scenarios but does the difference I’m hearing mean the cabs are only via headphones?
Given this, my main question is should I buy studio monitors or continue with a hifi setup? It sounded good through both but as above, a bit better via the headphone out. Assume it’d be no worse into monitors?
Cheers all
I had a Gigboard but eventually moved it on, not because it wasn’t great, but because it was overkill for me and I spent the majority of the limited time I had faffing with it rather than playing.
However, initially I used the return loop of my Marshall DSL1 and it was ‘ok’, but then I got a cheap pair of minutes - Presonus Eris 4.5, and the sound came alive. I would absolutely recommend going the monitor route if at home.
Hope this help.
Cheers,
Dave
some HIFI speakers might sound ok, I have some that sound great used as monitors, but certainly different to my Genelecs.
id say for home use get a pair of studio monitors, 5” or bigger. The headrush mentioned above would be a good option if ever you were going to gig with it.
or the HIFI may be an option, what is it?
My experiment was the same hifi just aux out of the gigboard vs it’s headphones out. Both times into the aux in of the denon. Headphone out sounded great - better than aux out so was wondering if monitors would be better again
id try some jack to rca cables and use the main outs from the headrush to the aux in RCA’s on the denon
no reason the headphone out should sound better, other than it’s louder
