The 12AY7 should still sound better at lower volume levels even with a pedal, it’s clearer as well as having less gain.
But if you have the TC anyway, try it - it's possible that the amp will overdrive more before the volume goes up, since these amps run the valve at quite a low voltage compared to 'normal' valve amps, so the result may not be the same.
