The Custom Vibroluxes I've played have also been noisy, if it matters.
Yes. I've never found Deluxes quite loud enough, despite popular wisdom saying they are - it's not the outright volume, it's that they go too muddy and flubby to give me the clean headroom and very light break-up I want at band volume... and I don't play that loud. I much prefered the silverface Vibrolux I had.
If the 'Custom' Vibrolux is one of the ones with no negative feedback at all, they can also be improved greatly and the noise reduced at the same time, by adding some.
If you can cope with the noise the stock CVR should fit the bill for you perfectly. If you were looking for "cleans" then a revalve and The Mark Moyer mod is the way to go.
