Which one to part with?
There have been a few expensive guitar related purchases recently and something should probably make way to maintain a harmonious home life in lockdown.
The problem is, I like them all for different reasons and there are pros and cons for each.
Candidate 1:
Original run Gibson ES339 - I sold it once, bought it back again a few years ago - quite serendipitously - as I couldn’t find another Gibson as good.
Currently loaded with some Oil City Masterwound Beano’s and probably the easiest to sell of the three.
https://www.instagram.com/p/BpC5tZ3lXYB/?igshid=opnr2pvklph8
Candidate 2:
A Lag Jet Master 3000. A premium guitar from an unfashionable brand, supreme craftsmanship and has outlasted the Anderson’s, Suhr’s, Eggle’s. Mahogany body, flamed maple drop top, one piece maple neck, ebony board with ebony binding and direct mounted DiMarzios.
https://www.instagram.com/p/B1rL9C2H7Nk/?igshid=8kl4tc80wj22
Candidate 3:
A Rocketfire relic tele. Seems to be a largely unknown brand in the UK. Early run from Nick Sorenson, 2009 model with a beautifully worn in neck, alder body and set of Lollars.
https://www.instagram.com/p/BvHjqDcnB75/?igshid=13da1pat1p3cn
Thoughts?
  • Sounds like you’d regret selling the 339 the most, so probably not that one!
    Those rocketfire teles are meant to be superb, and in that spec it should have a pretty broad appeal to buyers.
    The Lag’s tricky as they’re much more marmite than the other two - I suspect you’d get the least £ back for it, and might have to sell it for less than it’s worth to you.
    Toss a coin on the last two, or put both up for sale and let the market decide.
  • RolandRoland Frets: 8712
    Do you need the money? Do you need the space?
  • FunkfingersFunkfingers Frets: 14434
    Which would be the easiest to replace?
    Given Gibson's notoriously variable QA, I would keep the 339.
    I agree with those who say that the LAG would never recoup your original outlay.
    That leaves the T-type. Unless it has some unique fingerboard radius and fretwire combination goin' on, it should be the easiest to shift and replace.
  • axisusaxisus Frets: 28338
    Well I can't comment for anyone but myself but I like the LAG best, then the tele.
  • SchnozzSchnozz Frets: 1949
    Is the red les paul a Feline, Alex? Sounds awesome :)
  • JerkMoansJerkMoans Frets: 8794
    The 339 is horrid. I’d sell it rapidly. Cheaply :naughty:
    Inactivist Lefty Lawyer
    Yep. Long time number 1, Lion Supreme.
    https://youtu.be/qOEBuht8ONI
    Not seen that one before - Looks 'badass' as they would say on Cobra Kai.
    Rocketfire are as good as Bravewood in my opinion, but with proprietary pickups. I think Treewig and Cloud9/nine have had the S-type on here. Even I who hates Teles would play that.
  • RedFalconRedFalcon Frets: 171
    Out of the 3 - the Gibson is the keeper. Finding another one you like has already been proven to you as a challenge.
    I’m not blown away by the tele. Probably that’s the one I’d look to move out.
  • HAL9000HAL9000 Frets: 9678
    Keep the Gibson.
    Coin toss out of the remaining two. If you find yourself hoping the coin lands a certain way then there's your answer.
  • No question tele goes
    www.maltingsaudio.co.uk
  • ICBMICBM Frets: 72375
    This.
  • SteveRobinsonSteveRobinson Frets: 7032
    Great playing by the way
  • Keep the Gibson. You've proved it can't be replaced once before.
  • I'd sell the gibson. Its basically a les paul and you have said your number 1 is a les paul
