Generally the room with the most soft furnishings will be the easiest to tame, using a dynamic mic rather than a condenser will also prevent problems with noise from traffic, dogs, fridge, boiler etc.
Record a snatch and then heavily compress it and listen ... the compression will exaggerate any shortcomings so you can hear what's wrong and correct it. Once you have corrected it don't use massive amounts of compression in the finished piece, just enough to keep the level consistent.
