You're probably right, I'm not a recording engineer, but I was amazed at how a minute mic adjustment changed the sound quite drastically - and this was with a cheap mic hanging over the amp. In a more serious setting, I can't imagine valves being significant enough comps red to amp eq, mic placement, post-processing etc.
But I'm not a recording engineer - I'd just be really sad if I went to a studio to record and was told my valves were not good enough! I should probably get some new valves...
It's not something to worry about, but if you notice the difference, then it's worth it.
Bandcamp
Spotify, Apple et al
Everything in the chain matters. Just parts of it matter more than others. I don't think tubes are the primary factor. But they are one factor.
To me the amp head and speaker cab are the biggest factors.
How do you assess a recorded tone? That sounds like a stupid question, I know, but my cheap headphones sound quite different to my nice ones - so much so, my preferred tone was swapped!
I wish I knew more about recording. Sounds stressful, though...
Assessing a tone... you kinda need to just explore, and figure out what YOU like the sound of. My sort of tones wouldn't work for a brash indie rock or punk band. Their tones wouldn't work for a prog-band, probably.
But generally for me my recorded tones are slightly different to my live tones. Recorded tones a bit less gain, a bit more volume, and I use more mids in a recorded situation than I do live.
