Sold: Brand New Alegree Bridge P90 - 9.5k Alnico V - £25 delivered
Specs
- P90 Soapbar Bridge (Black) - 50mm spacing
- 9.5k with Plain Enamel Wire
- Long screws
- 27cm Braided Cable
Note that it won't install straight in my guitar (the pickup cants towards the neck, due to the way the cable is soldered to and exits from the baseplate) - pics of that in detail below
According to the seller, the reason the pickup won't install properly is is due to the 'unusual' pickup routing of the guitar and he has refused to accept a return
The guitar in question is a 2019 Gibson LP Special - pic below of the cavity concerned, so you can ensure this isn't an issue for you if you're buying it
https://i.imgur.com/7p2oouU.jpghttps://i.imgur.com/BPRk4li.jpghttps://i.imgur.com/0ZgF9Tf.jpghttps://i.imgur.com/fEbwQJ1.jpg
PM sent.
The OP has purchased a pre-owned pickup from an unnamed source. The first two replies assumed that the pickup had been supplied directly by its maker in the condition illustrated by the photographs.
Unlikely.
I currently own three Alegree pickups. One of them is a pre-production prototype. It could reasonably be forgiven for having a few "handbuilt" fabrication quirks and, yet, it does not.
Just to provide additional facts and confirmation for transparency:
The pickup is brand new - wound 2nd Feb, shipped direct to me and received 3rd Feb
The above issues which @Funkfingers has highlighted were flagged to the builder 4th Feb, along with these pictures
I’ve not made any mods to the pickup and it is 100% as supplied
It's never been installed, as with the cable like this, it won't fit
4 other brands of P90 have fitted just fine without issues in this route
Priced accordingly and hopefully YMMV?!
I agree that the solder around the output cable on the underside of the baseplate is both inessential and problematic. My inclination would be to correct the issue myself and mutter under my breath.
Just conscious that this is first and foremost a sales thread and I want to be 100% clear and factual on the description
The 9.5k wind should (theoretically) sound great
..in fact the excellent Lollar that I dropped into the guitar when this wouldn't fit is also around 9.5k / Alnico V
Pic of the two
https://i.imgur.com/5aW4vlT.jpg
At low 9'ish K, the Lollar combines great cleans with some proper snort when pushed - Leslie West (GRHS!) would approve
Obviously the Lollar is a very different kettle of fish, but I think I've priced this fairly and I would like to recover at least some of the £66 I've lost on it, if it's of use to someone as is
