Covering holes with veneer ?
JazzthatJazzthat Frets: 163
edited February 2021 in Making & Modding
Yet another quest I have to deal with on the Hondo neck I am slowly moving on .
After filling in old tuners holes , I have pretty much settled on just drilling new ones and move on .
But , the more I kept looking at that headstock , the more I wanted to look better than that ( photo ) .
Will it be viable to get some thin veneer to cover all that mess and sand it down to blend in with the neck ?
Or am I just going to far with this  ?
  • davrosdavros Frets: 1341
    I reckon the new tuners will cover the majority, and whoever looks at the back of the headstock!
    I would expect a veneer and refin would be much more obvious than the remaining visible holes.
  • JazzthatJazzthat Frets: 163
    That's what I was wondering about  .
    If I would glue a veneer , I think , it would look really good and clean .
    On the other hand matching the rest of the neck could be a challenge .
    I will put tuners on and take a shot in a minute . Maybe it won't look as obvious as I think it is atm.
    Definitely not going to be covered
    Apart from ' killing' my eyes , mole holes , there is another issue of three different wood pieces  pattern glued together , and if you look closely , there is a steel pin nailed in in far left corner !
  • WezVWezV Frets: 16733
    Think I would backstrap it, or paint a stinger
    Yeah, those fancy Schallers don't cover much up!
    A veneer would work - is it mahogany or maple? Getting a good colour match between the ambered neck and fresh headstock might be tricky though. A stinger would be the traditional (Gibson) approach to hiding the flaws, if you are ok with that look.
  • PeteCPeteC Frets: 409
    A highly contrasting veneer clamped and then sanding blended into the neck transition would work - but tricky !  You might need to router plane a mm or two off the back of the headstock first though so have a good look online at techniques first !
    the more experienced builders here would tell you how feasible that is
    Thats the backstrap idea.
    Doesn't look like you would need to route anything on this guitar as it has a nice flat transition into the neck already.  Although that could be done if you wanted to significantly increase stiffness.
    Depends on the guitar for me.   On a junior I would go with matching wood, on an archtop I would use something contrasting and make a feature of it.
  • As long as it is structurally good (if it were me) I'd leave it as it tells a story and think it looks quite good:-)
  • SargeSarge Frets: 2425
    A stinger can look ok if the low point is carried on down the neck like a skinny skunk strip.
  • DanielsguitarsDanielsguitars Frets: 3297
    Just going to say stinger, that would look good
    www.danielsguitars.co.uk
    (formerly customkits)
  • RolandRoland Frets: 8731
    This
  • Perhaps convince yourself of the wisdom of the Japanese world view of wabi sabi: https://en.wikipedia.org/wiki/Wabi-sabi
    I think , this method would work best in this case .
    Not sure yet , if to go with maple to match the neck or something that stands out .
    Off to eBay to search for veneer :)
    This
    I was going to , but not anymore :)
    What is the guitar?
    WezV said:
    What is the guitar?
    A Hondo HLP-2N , so I am taking this lightly and can experiment on :)
  • I have a guitar I call Van Gogh, because it has a bit of veneer missing
    www.theflyingacesband.com
    11reaction image LOL 0reaction image Wow! 0reaction image Wisdom
    Jazzthat said:
    WezV said:
    What is the guitar?
    For that I would go with matching maple veneer.
    I was incorrectly guessing it was something like a fatboy.   For one of those I would have matched the heel cap and backstrap to tie it all together.   that suits the big archtop look, wouldn't work here
    Done  :)
    It is a bit Frankenstein job , but at least I like it more than it was before .
  • Looks good.  Great job ;)
