From memory all the pitch shifting delay action comes from the algorithms on the pitch factor.
knock ~£80 of this and it's an amazing pedal, I just think it does a little too much and as a result some of the stuff is not great, but the majority is excellent, never tried the auto wah stuff on on it.
Had mine about 10 years I guess- still sounds excellent.
No pitch effects really, although you can repitch the looper using the speed knob.
The point is, you use the software to find the effects you want... tweak them, and then create a preset. If you're doing gigs, you can create a group of presets within a block or library, which means as you shift up and down, you only do so within that block or library (so that you don't accidentally skip out of your group of presets you want for a gig). You can add a multiple footswitch or controller.
And so, explore with the software, find all the effects you want, create your ideal effects, then forget about the software (unless you want to explore some more).
I wish they'd made it twice the size with more knobs and buttons- but given how much it can do I am not sure that would necessarily have hugely improved things, so I guess I see why they did what they did with it.
I'd really like to see them develop a full sized multi fx unit/modeller like the Helix.
I am absolutely loving the H9000 for the studio, I wish I could afford a second one for my guitar rig.
I do like the Time Factor especially how you dial in separately each of the dual delays. It’s something you can’t do on the Korg.
I'll see if I can find the settings
The Time and Space just sounded better to my ears than the H9, which always sounded ‘digital’...
Maybe it’s just me too
https://www.evenmidi.com/
