Rocktron talk box guitar pedal 110V with ac-ac converter safe?
musicalstashmusicalstash Frets: 53
Looking to sell a rocktron banshee pedal on behalf of a friend but want to make sure it safe before listing.
It's a 110v pedal but was supplied with a ac-ac converter block (see picture) with a 3 pin plug so it can be used in the UK .
It comes with its original 2 prong pedal but wanted to make sure before listing.
Thanks
  • ICBMICBM Frets: 72598
    No photo of the stepdown converter? You can't plug that unit directly into the UK mains, it's 120V only.
    You would be better getting a proper 230V 9vAC power supply, although it will work with a stepdown unit as well.
  • Thanks, it was just supplied with the two units.
    The original 2 prong power supply and the ac-ac converter.
    I have not attempted to plug either in.
    The second one is the right one.They are both AC-AC.
    Don't plug the other one in with any kind of plug adaptor, it would need a stepdown transformer.
  • So using the one below direct without an step-down converter be OK?
    https://ibb.co/jHc7wxX
    Thanks again
    Yes.
    Yes.
    thanks
