Opinions on Yamaha MSG Custom
13»
  • BorkBork Frets: 259
    edited June 2021
    I took my main MSG deluxe apart on Friday, between string changes.  I decided to take a closer look at the trem and what I found kind of shocked me.
    The two anchor bolts for the Rockin Pro were a very, very sloppy fit for the slots in the bridge.  Very poor potential for transmitting string energy.  At least a 1mm gap between the top of the bridge and the underside of the bolt head.
    So I found a spring in my spares department, snipped two coils out to use as spacers for lack of spring washers, and reassembled the whole thing.  The fit was a lot more snug and after setting the trem and tuning I was getting much more sustain after the initial pick attack.  I'll need to check the other one at some point but if it's a consistent thing,  it'll be a disappointing drop in Yamahas standards of engineering.
    [This space for rent]
