Trent Guitars - From the Workshop
  • TrentGuitarsTrentGuitars Frets: 1731
    Managed to shoot a demo video in the workshop this weekend, very pleased to have this on record!
    https://youtu.be/1RqjYnyqu8g
    So I have a Model 1 on the bench for the great artist Katie Harkin that's nearly ready to go to it's forever home - which I imagine will be back on the road at some point given her track record!
    Got the cavities shielded, body polished, just waiting for the pickups to come in!
    Shielded painted cavities always look really fresh..
    In other Model 1 news, the materials for the Founder's Club have been starting to come in, I just got the body material and the fretwire dropped by yesterday!
    Jescar fretwire is unmatched, it's the best!
  • sev112sev112 Frets: 2769
    Isn’t that what Mandalorian armour is made of ?  sounds a great choice for fretwire ;)
    Hahah! I'd have trouble shaping it if it was Beskar!
  • Benm39Benm39 Frets: 707
    These do look really lovely,  and sounding great too... a mastery trem version or similar and that's about it for me in terms of fabulous offset.
    It can certainly be done!
    Great day for deliveries yesterday..
    And I have this wonderful one out the door, first stop is via a local music shop to see if they might be interested in stocking..
  • punchesjudypunchesjudy Frets: 1025
    Banging
    edited June 2021 tFB Trader
    Banging
    Thanks man! Yours is being cut out today  ;)
    Banging
    Exciting!
    Just wanna say I absolutely love how the top and bottom horn have this Tele ish squareness that then rounds out towards the butt of the guitar. It does things to me.. good things.
    That was the thought with the shape - so glad it translates!
    So I'm spending the next 2 weeks making these 5 guitars as a batch,
    I've spent this weekend  getting a headstart for them beginning on Monday!
    First step was rough cutting my neck blanks, and then pattern routing them to shape - you can see the  screw holes pre truss rod route that I use to attach the template. I used to do double sided tape but you cant beat the security and speed of screws, especially if they get entirely removed by the truss rod route.
    Then on Saturday morning I took the chance to do my truss rod routes, I use a jig that holds my Festool track rail that allows me to run the router in the same way every time. The jig also holds this exact neck size the same way each time and clamps with a wedge
    In the afternoon I planed and glued together my five 2 piece body blanks, I then rough cut them and had them ready to plane today (Sunday)
    Sunday morning I cleaned up the blanks and put on my two roundover profiles, next step is to blend the transitions and finish sand the bodies before routing the cavities
    Solid Monday!
    Got the body cavities routed, sanded up and fitted the necks to the bodies. They are now wed together and have matching serials.
    0reaction image LOL 7reaction image Wow! 2reaction image Wisdom
  • TTonyTTony Frets: 27598
    That’s progress!
  • LebarqueLebarque Frets: 3876
    Looking fab. Are they glued on rather than bolted then?
    Thanks so much!
    They are bolt on, but I get the fit nice enough that they hold thier position quite nicely
    Another solid day,
    Got the bodies all drilled for bridges, jacks, strap buttons and ground cables
    Then final sanded and then sprayed with a couple of coats of primer.
    The primer I build coat on coat and then in the morning I'll flatten off each body with goldflex and apply the colour coats
    0reaction image LOL 6reaction image Wow! 1reaction image Wisdom
    Handy little shed you’ve got there
    Certainly is worth the cost!
