Just bought a Blackstar Artisan 15 combo.
  • ecc83ecc83 Frets: 1638
    Dominic said:
    very loud and good sounding up but treble can be a bit harsh
    Ah, There was at least one that had a cap missing. 'It'appen, which meant the amp was flat past 15kHz. If it ever goes into Blackstar's for a service ask for a specc' check.
    Dave.
  • relic245relic245 Frets: 963
    impmann said:
    If you want it to sound at its best, use a closely matched set of EL84s.
    Do have any recommendations to what brand of valves work well in these?
  • impmannimpmann Frets: 12669
    TADs are very nice - and are what is fitted by the Blackstar Service Dept.
    Agree with this.
    Not the same amp in my instance, I've got a hiwatt.
    I found the TAD valves were much brighter than the JJ's that came with my amp.
    It's by no means a negative, articulation and everything is great but as a result I use the normal channel only (I used to bridge the bright and normal channel).
