41mm nut - where to get one?
I've got an old Japanese strat copy which I've gutted and am replacing everything on. The nut is broken so I need a new one. Thing is it's 41mm length but all I can find online are 42mm and 43mm
 Does anyone have any idea where I can get a 41mm nut, or any other ideas?
Thanks.
  • CheesyfeetCheesyfeet Frets: 16
    Get a 42mm one and file 1/2 a mil off each end
  • JazzthatJazzthat Frets: 163
    Not sure if it would fit your neck , but Yamaha Pacifica has 41mm nut.
  • FunkfingersFunkfingers Frets: 14462
    This approach is fine for working from a blank but problematic with commercial, pre-slotted nuts.
    Working from a blank allows you to choose your own string spacing and match the fingerboard radius.
  • Try the tusq nuts, they’ve plenty of different sizes. Get the size and model number from their website and then find it for sale in the uk.
    https://graphtech.com/pages/tusq-nuts
  • TrentGuitarsTrentGuitars Frets: 1731
    https://graphtech.com/collections/tusq-nuts-guitar/products/tusq-nut-42mm-flat-bottom-strat-nut
    Closest approximation, 0.5mm off each side shouldnt be the end of the world with your string spacing
    Yes, .5mm each off each end isn't ideal, but a pre-slotted nut can often be a bit of a compromise anyway as you can't dictate exactly where the slots are or what angle they are filed to.  Obviously, using a blank solves all the issues, but it can be a daunting task and expensive to set yourself up with a decent set of nut slotting files.
    Brilliant, thank you for that.
    This is the best one, apart from it's about 2mm too wide, otherwise perfect: https://graphtech.com/collections/tusq-nuts-guitar/products/tusq-nut-slotted
    I'll just file it down.
    Can't believe how much money I've spent doing up this piece of junk guitar. Oh well - it's been fun and I've learnt a hell of a lot.
    Once I've got it in working order and played it for a while I'm stripping it all off and going to re-finish the body.
  • Best of luck feller.......maybe a few pics of guitar during its transformation or on completion.
    Thanks.
    Okay cool - yes will do.
    I took a before pic already, and have since changed the hardware and pickguard.
    Obviously the pickguard didn't fit so I had to file off quite a lot of it and made a dogs dinner of the part around the neck, so may well buy a new pickguard and re-do it.
