Tips on getting a Dual Rec to sound good
  • John_AJohn_A Frets: 3775
    Drew_fx said:
    Honestly? I don't think you're going to get a plexi sound from a Recto. I'd flog it personally if that's what you want. Get a Friedman or an old plexi!
    I have a plexi which is partly the reason I've got used to that as my main sound, wanted the rectifier for the versatility, but 90percent of the time I want a marshally main sound. Also got a blackstar S1 which is a bit lack lustre but just about gets the plexi sound and a lot more
  • ICBMICBM Frets: 72580
    edited July 2014
    No, but you can get much closer than you may think, and you have all the other sounds it can do as well… whereas the Plexi only has two sounds, and both of those are volume-dependent.
    That's why I play a Trem-o-verb and not a Plexi.
    (Granted, the Trem-o-verb is slightly looser-sounding and less direct than the straight Dual Rectifier, even with the trem and reverb turned off.)
  • DeijavooDeijavoo Frets: 3298
    I do like a good Boogie.
    edited July 2014
    Or is that I do like a good Engineering?
    Mebbe both!
    Nice sig ;)
    Nice wink.
