If it is the same it works well and the sounds are pretty good.
To me the HX Stomp had it beat in terms of amp sims but the second hand price of the boss was a third of the S/H price of a stomp and it's perfectly adequate.
I haven't recorded with it but I'm assuming it sounds pretty much the same as is coming out of my monitors so it should be fine.
If you do not already have an interface, then it a good option. You can’t lose as it still has audio outs. The newer GT units have IRs and more modern sounds.
