The others are acoustic amps and will sound fine with a clean electric for 'jazzy' sounds, but terrible with an overdriven sound, even from a pedal - unless the pedal has onboard amp/speaker emulation.
The Line 6 Spider V - 30W model and bigger - will take both though, since it has a FRFR mode. (The 20W claims to, but since it doesn't have a physical tweeter it will be a compromise.) I'd probably go for the 60W model if the budget is enough for the others.
It also does a decent job with my daughters mini strat.
Thanks.
Nil Satis Nisi Optimum
The earlier AC-2 is better than the more modern AC-3 - the AC-3 can distort in an unpleasant way if the guitar output level is too high, which it can be from an active electro-acoustic. (The AC-2 is discontinued, but fairly common on Ebay I think.)
