Wall socket
  • HootsmonHootsmon Frets: 15962
    edited July 2021
    it's a new house and new board is waaaaaaaay down the list
    tae be or not tae be
  • spark240spark240 Frets: 2084
    I don't see any board pic ?....only 3 cables In the socket suggests its spurred of something else, could even be a fused spur somewhere and it's popped when you plugging the Micro.,,,,check around see if there's anything about, in the cupboards,  under the cupboard above the cupboards, ...could be anywhere
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • HeadphonesHeadphones Frets: 991
    Nothing illegal about plastic casings.
    Someone says that they're trying to fleece you.
    No RCDs isn't illegal, but it is a jolly wise install!
    see the pic now @spark240?
    I do see it.....Ok its a dated board, and no RCD...I assume you have something added on as there is a power breaker unit low down? ...looks like you are going to have to do some investigation....do you have any means of checking if there is any power at socket at all?...i.e there may be a live and you have lost the neutral?
    Mac Mini M1
    Just moved in Sparky a week ago.......yup, that's some sort of power breaker.
    I will check and secure the 3 wires again and report back tomorrow days
    PS Is a RCD easy enough to install and worth the effort?
    It's a pretty small box for a modern home, but swapping the MCBs out for something like RCBOs should be possible and realtively cheap.
    That said, if you're not too familiar with leccy, calling on experience would be wise.
