NuAge Tonewood - Build thread
  • paulnb57paulnb57 Frets: 3078
    WezV said:
    It's not too bad.  They have matched the end grain pretty well so it doesn't jump out in most areas.  Just a couple where it's more obvious.  Will get some pics at some point.
    It will get a solid finish
    Cheers!
  • WezVWezV Frets: 16806
    edited August 2021
    Added some more chambers.   Also changed neck for a large headstock allparts one.
    With more hardware and a bigger headstock than previous weigh ins
    That will do.   On to finishing soon
  • PhilKingPhilKing Frets: 1496
    You could recut that headstock for a bit more of a Bigsby look, given the pickup.  I think it would make a great statement.
    Wouldn't take much at all, maybe I should
    maybe???
    0reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • Looks really good. I reckon your plan on the headstock will look great and shave an epic 5g off the weight. :)
    I really think it will look great like that.  It's just different enough in the headstock shape to be distinctive.
    I did it.
    Also got a coat of white primer on body and head.
  • CorvusCorvus Frets: 2966
    Nice... the new head goes well with the p/g shape too I reckon.
    It's now a creamy yellow,  somewhere between the two pics below
    Needs buffing out properly.  But so far so good.
    The NuAge Rosewood took a finish pretty well, but it did drink up more lacquer than I expected... certainly not like the fully acrylised wood I have used before, which was more like plastic than wood.  This stuff behaves like alder or basswood when finishing with lacquer
    its come together rather nicely.
    I want to give it a bit of light ageing still, but its wired up and playable
    the pickup seems pretty good, loads of clarity and more power than I expected... will see how it copes with a bit of gain soon
    break angle over the bridge is a little low, but strings are staying in the saddles so no issue.  I am kinda tempted to put a screw through the middle of the diamond with a spring underneath so I can control  break angle a bit
    I think the end result looks like a cheap 60's catalogue guitar, somewhere between  dano, supro, guyatone, teisco etc???  Funny how mixing fender, gibson and bigsby got me there? Thankfully it's a lot more playable and reliable than the looks suggest ;)
  • SteveRobinsonSteveRobinson Frets: 7083
    Needs a fancy arm rest and your name inlaid in the pickguard ;)
  • RabsRabs Frets: 2618
    edited September 2021 tFB Trader
    Pickguards do funny things to the eyes in terms of how you perceive the rest of the body... Like a person with a completely different haircut like going long to short can look so different but still obviously be the same person..
    Nice 1
  • It looks great! Now it just needs a B7 bigsby :)
    I actually checked with a bigsby copy I have here, position of the bridge is a little further back than a LP due to the extra scale length, so it sits too close.
    If I had thought about it sooner I might have gone that way.
  • Winny_PoohWinny_Pooh Frets: 7814
    Yanuziello does a cool thing, he chops off the roller bar from a b5 and grinds and polishes the rest up till it looks like so:
    He also recesses it very smartly
    A b3 would fit too, just the B700 clone I have here touched the bridge posts.
    I did try a vintage teisco  trem too, but couldn't bring myself to do it
    Looks great Wez, very old looking, the pickup and the knobs help too.
    Yeah, I'm going with it and adding a bit if ageing.  So far jutst a few chips, small bits of wear through and a little dirt
    All done now.
    The NuAge body has worked well.    Its final weight is 8.9lb.  So weighty, but not crazy heavy
    The nitro finish has carried on shrinking into it, more than I expected... It even looks a little ridged in places now.   I had assumed the treatment on the wood would reduce this, but its actually behaved just like wood does.
    I  added some more ageing to the neck.  Also put a screw though the tailpiece with a spring underneath so the break angle can be controlled.
