WTB: Four Pot Loom/Harness
Looking for a two volume and two tone harness for approximate Les Paul/SG spacing.
Not overly fussed on the what brand/type the caps are, but need good quality pots. A decent three way toggle somewhere in there would be a bonus too.
Happy with a straight up money purchase, but also have pedals, etc, I can trade with cash either way.
Thanks for looking in!
  • FunkfingersFunkfingers Frets: 14613
    edited September 2021
    Pick one or the other. Some important aspects are different. Mainly, that the carved top of a Les Paul Standard, Deluxe or Custom demands long shaft pots to achieve a secure fit.
    SG and Les Paul Juniors, Specials and a few other flat-fronted variants require short shaft pots.
    If you will be using push-pull or push-push pots for additional switching, ensure that the control cavity of your SG can accommodate them.
  • FelineGuitarsFelineGuitars Frets: 11651
    I have some Gibson looms out of Les Pauls on the diamond shaped aluminium grounding plate...long shaft pots as i recall
  • KittyfriskKittyfrisk Frets: 19142
  • @sixstringsupplies does pre-wired harnesses too. Depends on how sophisticated you need your controls to be.
  • It's going in a LTD PS-1 X-Tone, which is a semi-hollow offset arch top. Needs to be have little bit of flexibility in the fitment/spacing, so a plated/fixed one is out, sadly.
    I bought a Mojo one a while back which would be perfect, but that's staying in my Gibson.
    Thanks for the links. One of those will be where I'm going unless a 2nd hand one pops up for cheap.
  • SlimbertSlimbert Frets: 341
    One last bump, on the off-chance someone's stripped a four pot guitar recently!
  • ricorico Frets: 1220
    I’ve got a couple!
    Still looking!
