What Finish?
I'm just getting into my second build, a Tele with a Poplar body and maple neck. It has a slightly "eccentric" shape in a couple of places such as the lower bout and the lower part of the headstock thanks to over-enthusiastic routing requiring some heavy-duty sanding. That said, i'm quite pleased with it so far.
Anyway, what finish should I use? I have several guitars with a Tru-oil finish and fancy a change. I have some black hard wax oil and a couple of types of wood stain. What do you reckon?
http://i1121.photobucket.com/albums/l512/dean2371/photo_zps1b29d958.jpg
  • dean2371dean2371 Frets: 139
    its very unusual for folk on here not to have a view!
  • CorvusCorvus Frets: 2966
    I read it, but there's so many choices and folk like certain things, plus Teles look great in so many things. Wax & stain sounds good. I like 'em all ways from straight ash in lacquer to flaked & candied to hell, it's all good. Keep the progress pics coming :)
  • TTonyTTony Frets: 27707
    To my eyes, the grain pattern on the body isn't wonderfully striking and looks a bit multi-coloured (unless that's shadow on the bottom section?).
    How about considering a veneer (there's a great tutorial on veneering in the theFBChallenge sub-section) or maybe Wudtone to even out the colour variation and accentuate the grain pattern that you've got.
  • GagarynGagaryn Frets: 1553
    Since you are looking for opinions, I'll give you mine - good old fashioned paint in a colour of your choice. :-)
  • ICBMICBM Frets: 72677
    Black.
    What was the application again…? Oh a guitar. OK. Still black.
    Thanks for the views. I had thought ao veneer having read the thread in the Challenge section. I have in fact bought some , so maybe I'll go for that. Black has been my second choice as I have some black hard wax oil. I guess I simply need to take the plunge
  • WezVWezV Frets: 16797
    take the plunge.... and sand it off if it doesn't work!
    I think it's most probably my fault ref the veneer threads - I'm being crossed off the christmas card lists of FB members at an impressive but alarming rate  :))
    If you go this route, feel free to ask if you get stuck.  I have other threads on other forums in a bit more detail too - I can post if you need them
    Andy
    Been there...done that...  :)
    Thanks Andyjr1515. I've been following your thread and the link so perhaps I'll give veneer a go. The poplar is not very inspiring, and I have some swamp ash on the way for another build which should benefit more from an oil finish.
    Or if the veneer doesn't ...
    :D
  • BilliBobBilliBob Frets: 19
    Tung Oil
  • imaloneimalone Frets: 748
    Shellac! Maybe not. Veneer sounds fun. Would be interesting to know what the black wax turned out like, is it like this http://www.restexpress.co.uk/acatalog/Fiddes_Hard_Wax_Oil.html ? If so it might even out the colour but leave a grain, or (again) maybe not.
    It's Blanchon hard wax oil, sounds very similar. I've got plenty of stains and oils and a load of veneer, so may do some experimenting over the next week or so
