It's oil based and seems pretty durable.
The idea is that I will fit 5A mono jack sockets, and in normal use they will be connected with a 5A patch cable. Then if I want to send the signal out to an external cabinet, I can plug the cabinet in AMP OUT, and if I want to use it as a speaker cabinet with an external head, I can do that too through SPEAKER IN. The text size is approximate, could be a touch smaller, and maybe in Bold, ideally in white to match the rest of the text, but this is the idea.
Any suggestion as to which? Maybe I could do that over a stencil. Options are good hywelg said: That is very kind of you, thank you very much. I have a Brother label printer, but I only have the black on white option. If other options don't work, I may come back to you, if that is all right, with some white on black. I can pay, or pay the forum in return.
That is also an option, any links to the products you are suggesting?
Yes, I might check to see if I can buy black tape and white ribbons for my label printer, or whatever else they use.
That brings back memories. That would be an option, but hard to find white letters of the desired size. Any website that sells a large selection of them?
