My DC30 suddenly got very boomy in the low mids
ToneControlToneControl Frets: 11933
around the 12th fret on the bottom string
suddenly all the guitars I try are mid-heavy and woolly
is this just needing a valve replacement, or a trip to the amp repair shop?
  • Mine used to mince up EL84s regularly.
    Assuming you get the same on both channels?
  • ICBMICBM Frets: 72442
    Sounds like one or more of the EL84s might have become microphonic and 'loose'. They do that...
    As Moe says, they eat EL84s at a rate of knots - that comes from running them at well over the rated dissipation even at idle.
  • FuengiFuengi Frets: 2850
    I'm sure you're better at noticing these things than me ... but that happened to an amp of mine and it turned out to be the A string vibrating on the top of my Filtertron pickup.
  • ToneControlToneControl Frets: 11933
    I tried 3 different guitars, with very different pickups, very sudden too
    so replace just the EL84 set?
    Yes. If you own a Matchless it's a good idea to keep a spare set of EL84s at all times anyway :).
    any tips on brands at the minute?
    JJs probably, of the new production. They're tougher than any of the others.
