SG - Reversing an added bigbsy back to TOM or other trem
John_PJohn_P Frets: 2750
edited October 2021 in Making & Modding
I saw this 70's SG for sale today that looks great apart from that someone has added a bigsby (B5?) and plugged the holes from the original tail piece.
What are the easiest options for replacing it?     A longer bigbsy or maestro would look a lot better.
https://i.imgur.com/RI4PJIM.jpg
  • stickyfiddlestickyfiddle Frets: 27120
    edited October 2021
    You could always do a Derek Trucks and put a Maestro frame & cover on it but still with the TOM. Or.. put a Bigsby back on??
    EDIT: I can now see the picture. Keep the Bigsby!!
  • ICBMICBM Frets: 72448
    Given that there's sure to be a horseshoe mark where the finish hasn't faded as much, I'd leave it. It's cooler with the Bigsby anyway - especially as it's a Gibson-logo'd one. The problem is that it's been fitted crooked, so it will still need plugging and redrilling, but it shouldn't leave a noticeable amount of the horseshoe mark visible.
    Also notice that it has such a low neck angle that the height wheels for the bridge have been recessed into the top, at least on the bass side, if that matters...
  • FunkfingersFunkfingers Frets: 14476
    If that SG has already been refinished after the tailpiece inserts were filled, there is no originality value to be lost by having it finished again.
    I would argue that it is worth having the neck steamed off and reset with a steeper pitch angle.
    Such an undertaking will not be cheap. Given the variable quality of Gibson guitars of that era, it might be wiser to purchase a pre-owned reissue '61 SG/LP.
  • WezVWezV Frets: 16732
    I would just take it off and redrill the plugged holes
  • flyingvflyingv Frets: 555
    edited November 2021
    And you get to keep the B5! 1  I’ve got some repro ones somewhere? Your more than welcome to one.
    https://i.imgur.com/0HkQdDY.jpg
