Recently got a 18w OT from SteveUK, what to build?
brooombrooom Frets: 1175
edited October 2021 in Amps
So I recently got a 18w output transfomer from Steve Uk. Kind of looking for ideas on what to build, as I have an aluminium chassis from modulus and an edcor power transfomer.
I'm thinking either a super simple (normal channel only) ac15 or a mini jtm45 with 6V6 output.
Any opinions are welcome.
  • equalsqlequalsql Frets: 6136
    Do you like tweed amps like a 5e3 or 5e7? Solid state or tube rectification? Got any piccies of the chassis you can post up?
  • brooombrooom Frets: 1175
    I have a 5E3 and a clark 5E7. My edcor has a 5v tap so I'll be wiring up a rectifier for this one.
    It's a small chassis 35 cm wide, but I can fit it all in there.
  • ecc83ecc83 Frets: 1636
    edited October 2021
    6V6s with a sstate rect. Add a 'sag' resistor if you want. You could even run EL34/6L6 wiith appropriate biasing.
    "tap" or isolated winding?
    Dave.
    edited October 2021
    Sorry, I meant isolated windings, not a tap. I'm happy running small bottles (el84/6V6) the OT is also made for an 8k primary which is ideal.
    So ac15 or jtm type of circuit?
  • Modulus_AmpsModulus_Amps Frets: 2583
    JTM with a fixed bias power section and presence control, will sound like a mini black flag amp and kill most 18w amps.
    You have to get the feedback right, a variable pot would help with that.
    Good! Needs to be isolated to run a GZ34 which IS overkill for 18W but should last a long time. I am however not keen on 'modern' thermionic rectifiers (the TAD is about the best GZ I found) and if you go for diodes your traff and amp will run cooler.
    Dave.
    Thanks guys... Ok so I need to make a parts list for modulus.
    Looks like it could be a fun little amp
    I built an 18w hot rodded M style amp, fixed bias and thought it was the best 18w amp I have built so far.
    You can hear it cranked up in this video, but it does amazing clean tones too
    https://www.youtube.com/watch?v=_A4MjfH1Vn8&t=423s
    edited October 2021
    I'm looking more at the "bass circuit" end of the spectrum but that does sound nice, thanks for the video.
    I'll give that a go, I'll probably need to adjust feedback and maybe the power rail nodes a bit.
  • Rich210Rich210 Frets: 577
    What about something like a princeton, but with middle and presence? Maybe add a bit of a lush spring reverb.
  • RiftAmpsRiftAmps Frets: 3171
    8k Pri @ 18w?
    Lots of options but with a 275-0-275 PT and GZ34 rectifier you'll get a B+ of approx 375v at the reservoir cap, assuming three preamp valves.
    I'd do an 18w JTM with Reverb, easy.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    edited October 2021
    Bingo @RiftAmps my edcor pt is 275-0-275 and 150ma so definitely enough for a jtm circuit.
    The OT is 8k primary around 18w:
    https://www.ebay.co.uk/itm/265238831413?hash=item3dc1776135:g:RGQAAOSwAPZg-Uz2
    @Rich210 - not something I'm considering as I already have a Magic vibro prince
  • ICBMICBM Frets: 72407
    +1
    Mini Black Flag with either EL84s or 6V6s.
    Cool, thanks guys, looks like that's the topology I'll be aiming for.
    Thanks to the guys who suggested fenders as well. I live those circuit, but I've got them covered already.
  • pluckbuddypluckbuddy Frets: 278
    edited October 2021
    I have the same OT and am planning a JTM, superbass, tweed bassman, Vox top boost mashup - they all use the same basic topology - with a 2x6v6 power section and no negative feedback.
    Merlin's preamp book has some suggestions to reduce blocking distortion which i might incorporate. Mainly they reduce bass and change the phase inverter bias.
    If I can bring myself to drill another preamp tube hole in the chassis, I'll add reverb with the reverb recovery stage going into the second PI input. I hate drilling chassis though - too much hard work and concentration required!
    Then find  a small engineering shop and bung them a few quid to punch the hole for you.
    Dave.
    My chassis is 2mm aluminium... So routing some holes isn't really that much of an issue.
  • Yes mine is an ampmaker alu chassis of modest gauge and should be manageable. I have access to a pillar drill and the right drill bit too. And yet I'm still expecting it to be... ugly. lol.
    I should just do it.
    edited October 2021
    Oh I just drill it with my standard black & decker drill and then expand the wholes with curved/circular/tapered files. I don't have the proper tooling. But it's usually only a couple of routes so it doesn't really take too long.
    See if you can borrow a Qmax chassis punch then grease it well.
    Dave.
